02-07-2014, 20:01
Plasser & Theurer SSP 2005 SWR Ballast Distributing and Profiling Machine (For tracks, switches and crossings with ballast hopper)
Machine with two 2-axle bogies carrying: split center plough, suitable for ploughing in tracks with line conductor, ballast flow can be selected via symbol switch, shoulder ploughs, sweeper unit with transverse conveyor belt, steep conveyor belt and ballast hopper with floor conveyor belt and distribution chutes, hydrostatic drives on all axles, UIC brakes, spacious cabin with 2 driver’s desks and end windscreens made of 14 mm safety glass.
Variable machine accessories: dust arresting atomizer unit with water tank, sweeper unit displaceable by ±100 mm for work in station platform area, loading device for brush shaft, rail fastening brush, slewing limitation for shoulder ploughs, cabin fittings, inductive switches, driver’s safety device and train radio, pneumatically operated barrier to access steps, external controls for driving function.
Technical Data
Length over buffers: 19 000 mm
Height over top of rail: 4 630 mm
Width: 3 100 mm
Distance between bogie pivots: 11 500 mm
Wheelbase of the bogies: 1 500/1 800 mm
Total mass empty: 53 t
Engine output: 400 kW
Max. travelling speed under own power/towed: 100 km/h
http://www.plasserindia.com/en/machines/...00-sws.htm
Technical Data
Width: 3 100 mm
